DP44 and uS575-T possible?
trinidex
892
I'm using a Legacy LNB for 61.5 reception and DP LNBs for the other locations.
Is it possible to use a uS575 stacker between the DP44 and the 61.5 LNB to get both polarities on a single cable?
OR
Can I connect both ports of the 61.5 LNB to 2 ports on the DP44?
TIA
You would need to put a DP single or twin lnb on 61.5, then run to the switch. Legacy and DP or DPP equipment do not work together.
That's what I thought, was hoping for an easy win !
Well, that DirecTV stacker might work except it's not made for Dish. It's doing approximately the right thing to convert from legacy to bandstacked, but it may not respond like a DP dual. I agree with garys; probably cheaper just to buy a DP dual or single.
Dish 222k receiver with OTA module signal fade with HDMI plugged in
hooking up 2nd hd turbo Dish
