Here is what I have. Dish 500, dishpro, DPtwin, RCAdp301.
For the last couple of weeks I have been getting error 015 for a couple of seconds and then it the picture comes back.I'm getting this on both satellites and different transponders,but it mostly happens late at night on 110 spotbeam 2 (local channels). When I go to point dish,signal strength is between 110-123 and goes between locked and wrong sat.not locked with no change in the strength bar. This seems to happen late at night if that helps. our weather has been clear between mid 70's day to mid 50's night.
Been on the phone with dish tech support, pulled the smart card several times, hard reboot, check switch. nothing helps.
I saw somewhere on here to check the voltage from the receiver, it's at 20Vdc on both satellites and all transponders. I also unhooked the cable and did a check switch and then hooked back up and did a hard reboot.All test check out o.k. but still losing satellite lock.
I don't have anyone local to test receiver. So should I buy a new receiver or a new lnb.
