Looks like I am missing all left hand polarity channels, I tried +13v with no change in channels received.The DP Single is only hitting one Satellite
What dish are you using? You need at least a dish 500 with a TWIN LNB, for HIGH DEFINITION you need a 1000.2 with an Eastern Arc or a Western Arc LNB.Looks like I am missing all left hand polarity channels, I tried +13v with no change in channels received.
It's a 500 dish with single dishpro lnb pointing @ 129, how does the receiver switch between bands?Are you sure it is not a legacy lnb.
The dish pro lnbs "stack" the left and right frequencies so all frequencies are transmitted continuously to the receiver.
There is no 13 or 18 voltage like the old legacy lnbs require.
No, because you're not seeing the channels on the 110 and 119, only the 129. It was posted above witch Dish/LNBF you needIt's a 500 dish with single dishpro lnb pointing @ 129, how does the receiver switch between bands?
Would a legacy lnb with proper voltages switch and give me my missing channels?
Thank you, will look into this protocol and try to emulate. CheersProbably DiSEqC control.
I am now hooked into 2nd dish 500 with dpp lnb pointed at 110 and 119.
129 separate dish screwed into aux. port of dpp aimed at 110-119.
Only right hand polarities on 119 work and no switching to 110 or 129 is taking place.
How does the vip211 switch lnbs or channels if it isn't voltage?
By substituting what the ird can't provide?How can one expect Rube Goldberged equipment to work normally?
Get a new receiver it's the only way you'll get your service
