I have a DP301 013. When I hook up a single DP dual lnb directly to the DP301, I can pick up and lock on 119. I can also pick up 110 (manually adjusting the azimuth), but the DP301 won't lock on it - just displays the "wrong sat" warning. I know it is picking it up because I switch the coax to a receiver card in my computer and can scan channels on 110.
When I hook up a DP Twin, the 110 side/lnb doesn't pick up anything, even if I cover the 119 side with tin foil. However, I can get 119 and 110 (separately) with the 119 side of the DP301 with tin foil over the 110 side, but again, no lock on 110.
Is the 301 013 unable to properly pick up 110?
