When it comes to cabling, I see most dishes with the lnb cabling carefully tied to one of the struts, over the rim and back to the mount for distribution. Other dishes have a buttonhook arrangement where the cable just heads straight for the middle of the dish. Since the direct route to the mount is a lot shorter than the rim alternative, is there a reason why in some cases the rim route is preferred?
I realize that a small 'shadow' would be caused by the presence of part of the cable using the centre route. Is there a situation where the shorter cabling would offset the shadow caused by the cable? My 2 channel masters both have plastic plugs in the centre of the dish as if they were put there for this alternative, but I have not seen it used.
