My dad's VIP211 is having a problem, so I went over to check it out and called Dish for him. (he's 80, non-technical, and has very bad vision)
His 211 has been stuck on the Aquiring Satellites screen all day, and just cycling through the transponder on 119, staying at step 0 of 5 (I'm pulling this from memory, my verbiage might be a little off).
I called Dish, and they wanted me to run a Check Switch, since I had already done a few power cycles (including leaving the receiver unplugged for a few minutes) and always get the same result (looping thru Sat 119 transponders).
His other receiver is a 625, and it's running fine. Although I did not try out channels from all birds, or check signal strength when I was there so maybe it's not completely happy... (will check tomorrow).
The Dish support rep said to call back when the sky was clear, as running the diagnostic she had in mind could cause the other receiver to go out.
So I asked her if this diagnostic was Check Switch, she said yes. Well, I can run that myself easy enough.
But what's this about it causing problems on the 625 if there's a little foul weather signal degradation? Since I know just enough to be dangerous, I'm holding off and doing what she says - although I think the weather looks bad here for the next several days (Northeast Massachusetts.).
Is that for real or was she trying to get me off the phone cause maybe it was quittin' time or something?
My dad has got a VIP211, a 625, and two dish's - one for 110/119 and one for 61.5. Don't know the exact hardware of the top of my head, but it's a pretty standard New England setup done less than a year ago.
(Edit - just noticed another thread here about ice on the dish/LNB's - I'll definitely check for that as we've had freezing rain, but wouldn't that mess up both receivers and not just the 211?)
