What format is actually saved on disk? If it is MPEG4, it should consume less space than MPEG2.Scott Greczkowski said:Nope,
Mpeg 4 is smaller so would take less time, besides all reads and writes are done in almost real time.
I have played with MPEG4 a bit and it IS slower then MPEG2 when changing channels, when I played with it it took 4 or 5 seconds to change channels. Hopefully they can fix that or there will be no such thing as channel surfing.
kavula said:Then why did you say "Nope"?
Pepper said:I think Scott may have misunderstood the question, and answered as if it meant "will it take more time to record stuff" instead of "will it provide more available time for recordings"
If the program is encoded in MPEG4 it will take about perhaps half the file size that MPEG2 would have taken therefore more programming could reside on the hard drive.kavula said:Then why did you say "Nope"?
I don't suppose MPEG2 stuff gets converted to MPEG4 when written to disk? Thought not! lol
You have killed my excitementgoaliebob99 said:where i can see this going is you will get your 100 hours of time... and the rest of the free space will be used for vod..
markusian said:I started dreaming already. MPEG4 means More HD & More DVR rec. time.
By the time MPEG4 DVRs are out, the disk size will be 500G.
This means 50 hours of MPEG2 or 100 hours of MPEG4 HD.
And if we're talking about a new MPEG4 DVR, it may come with a smaller HDD to make it more affordable, negating (or minimizing) any increase in time available for recording.
Yup - heck you can't even get little HDDs any more.John Kotches said:foxbat says:
Drive space gets cheaper for the same capacity on a regular basis. This negates your argument fairly handily.
Cheers,
