Does channel master software work with the GEOSAT PRO 1000CI?
trm30
6
Eastern NC
Hello,
Does channel master software v1.20.3 work with the GEOSAT PRO DVR1000CI? If so, what receiver do you pick in channel master? Also, it is just a matter of plugging a serial cable into the receiver and then run the import? I have never used channel master and thought I would give it a try.
Thanks,
Tim
I know it works on my geosatpro 200. I select "Conaxsat" as the brand
If the receiver has a USB port, just use the USB option in the receiver
Here is what I do with the 200
plug a usb thumb drive into machine
select USB in the menu then save
power off machine to remove USB
plug USB into computer
In Channelmaster select "import" then wizard
select Conaxsat as brand then next
find the file and open
I usually save it as a CM job right after that. Now to export it you go to export and do the same thing (the file wont be a channelmaster file then but one that the geosat can accept)
Well TitanTV just ticked me off!
Invacom QPH-031 Used with Six foot Satellite Speial Dish?
