Think I remember reading that some use High speed CW (Morse code); might be receivable using a Ku LNBF/dish, SDR dongle, and software to read the code.
Thank you for your reply.
Sounds interesting. I have several SDR receivers. One receives up to 6GHz, the ETTUS b200. There are several software programs to explore the satellite spectrum further. Ex HDSDR, SDRconsole, GNUradio and others.
This gives me some hope for reaching the topic further. I took down my c band dish the day before hurricane Mathew came within striking distance of my location. I now need to put the dish back, but want to make changes.
1. Use the satellite ID to aid dish alignment.
2. Radically improve the Dish mechanical mounting method.
Add a bearing, ball or roller, for each axis of rotation.
Add an optical encoder for each axis of rotation. I would like change the single axis polar mount to a three axis Az,El, polarization mounting method. How about 1296 MHz EME?
3. Add servo control for each axis. Pipe dream dream of Point A to Point B < 1 second.
4. Use Internet protocol for data link rather than using DISEQC. Fairly simple with Rasbury Pi and several other low cost CPU boards, even for servo control.
Rob
