So you're saying a diplexer will fail where a splitter and cable with fittings won't?
Your basis for this is what? The "law-of-averages"? Your claim doesn't make much sense. One will work when the other won't? With that logic then what if the VOOM box goes bad? Both won't work. What if the TV goes out? Get my drift? So anything can "fail" so your theory doesn't float with me.
So far no one on any of these post anywhere has made any REAL reason why diplexers and multiswitches that are specifically designed to combine OTA and satellite signals, are so "bad" all of a sudden. Help me and everyone else understand why not to use diplexers?
Don't get me totally wrong, sure, if a crummy quality diplexer is used then you WILL have problems, no different then if the installer uses crummy cable, fittings, splitters, metal staples...
So come on everyone, this entire idea of "forcing" the installer to run separete cables for the OTA and SAT are NOT FOUNDED ON ANY REAL RESULTS ON ANY CONSISTANT BASIS.
This of course is my opinion, based on more truths than ficticiuos ideas of a possible failure of a part that has a higher proven track record of working properly as designed for many years past.
There are FAR more important issues than "forcing" the "DON'T USE A DIPLEXER ON MY INSTALL, OR YOU CAN JUST LEAVE, MR. STUPID INSTALLER, BECAUSE I READ THAT DIPLEXERS ARE BAD, BUT I DON'T REALLY KNOW WHY"
