Tron said:
			Toroidals are very tricky to install.  Are you sure your elevation and skew settings are correct for EACH LNBF?  If the skew is off, the LNBFs away from the center will not get adequate signal.
I have not yet installed my T-90, since I am still searching for a NPRM for it and am on a tight budget the rest of this month.
Dish was set up and working fine at another sight. I didn't disturb the setting, just moved down the street. Same Skew, Elevation and Azimuth. The new sight is very obstructed though??????????????? The signal meter is picking up the signal on the the most east and west satellites just fine. (can even tune some channels). So I believe this is not an issue with the dish aiming.
Setting up the T90 has been very straight forward for me; This is what I advised other T90 owners.
"http://www.satlex.de/en/wavefrontier_calc.html (Calculator is incorrect on one side)
Determine the 40 degree part of the arc you want to cover.
Determine your center satellite.
Align the dish with zero skew to the center satellite.
Pick one most west satellite and one most east satellite, both of which are strong and adjust the dish skew until you can receive both.
Readjust your center lnb, and start installing the remaining lnb's for that part of the arc.
Azimuth is not critical because the lnb mounts slide and make up for the azimuth being off a degree or two.
Elevation is a very critical, like 1/8 turns of the nut!!!
Skew is a compromise, ie you may be able to get a 10 signal strength on the most east and west satellite. but the best you can get on both is an 8 as a compromise. for example at skew of 50 degrees west satellite is a 10. at skew of 56 degrees east satellite is a 10. the compromise is both satellite received as an 8 with the skew at 53 degrees.
I have had great success with shimming the lnb's up slightly after tunning the whole dish. I place a wedge between the lnb and the holder. Gets back the higher signal lost during compromising on the skew. I have tried readjusting elevation (That what the wedges do) but can not get the improvement that the wedges give.
14 satellites on one dish, you gotta love that."
Thanks for any suggestions. Hope to try relocating the dish today.
