DishPVR 721 slow channel changing
chaseme5
Hello everyone,
I recently bought a 721 from ebay. After spending $200 on upgrading to dish pro plus and new cable because my old cable could not handle 2 tuners on one feed, I finally am up and running. However changing channels is very slow. Sometimes it takes up to 10 seconds to change channels. It does not matter if I am recording 2 shows at once or no shows at all. there is a very big lag when changing channels. Is this normal for this unit? Is there a buffer setting or something like that?
It should only take 4-6 seconds.
If it is taking longer... it has old software or the smart card is having problems. It could be an lnb problem. If you just got it from someone, I would suggest wiping the software out and re-installing it.
To get your 721 back to almost the way it was when you got it...
1. Menu->6 System Setup->5 Diagnostics
2. Info->Right->Left to get to Debug Status Screen
From Debug Status Screen :
Delete all Persistent Files plus recordings.
1. Info->Down->Up
Clear NVM Ram (Settings, favorites, checkswitch, etc)
1. MT+BT Button and then reboot.
EPG Data Delete (Delete all GUIDE files)
1. Info->Up->Down
Revert to Factory Code(Actually last downloaded software version)
1. Recall->PageDown->Up
I would try those in that order and see if that fixes your problem.
Thanks. Useful info. Is there more cmds for 721 and 921 ?
1. Info->Down->Up
1. Info->Up->Down
Dead 622 ? Any tricks to try ?
Need help with service
