Any one here have DISHnet? If so how do you like it? Also can a DIRT member tell me if it is available in my area?
I've had a tech and they say everything is fine here, All the neighbors seem to have the same problem! (Just found this out about a week ago) Wish I had other options. Seems that I will be out of luck either way I go lol!!I'm confident you can get service there. If you weren't quite so far from me I'd help myself. Pretty sure you are in the same beam as we are here in the Savannah area. I wouldn't count on using the streaming or sling function on your Hopper if you do go the sat route. You could eat up 20GB in no time. 4Mbps isn't bad for DSL really. Stinks though if you deal with frequent outages.
Have you ever looked into the reason for the down time? Do you have filters installed on all land line phones in the house and anything else that may be connected to the phone line (fax, hopper, ect.)? I had a real bad problem a few years ago at my place with AT&T DSL dropping out all the time. Turned out to be the old wiring in my house. Tech came out and we ran a cat 5 cable from the box outside directly to the modem location and put the DSL filter in the box out there. Never had another issue.
I'm certainly not saying that your provider isn't at fault but its not necessarily the case.
Oh, and keep in mind too that the 20GB plan is actually a 10/10 deal. You get 10GB to use during the day then 10 additional to use between midnight and 6am I believe.
My DSL provider is windstream and partners with dish but they suck ass!
Posted from my iPhone.
DISHnet is available everywhere in the USA.
When they install it, you will get installed with Hughesnet or Exede service installed.
I have used it a few times and it works well, however be warned it does have low bandwidth caps.
