Why does DISH give me a message "router not detected?" I have a Netgear nighthawk router, and my internet works fine for my work and home computers and phones. I just cannot get the premium channels to work. Any suggestions? Thank you in advance.
I did up my network and the receiver we have is HOPPERHave you set up the network on your DISH receiver? Which receiver do you have?
You might try to reset the network. Home 3 times, Network, Reset Network.
No, I keep trying to figure out what step is missingDid that fix your issue? What premium channels are you trying to access?
We have trying to access Netflix, with no resultNo, I keep trying to figure out what step is missing
Yes, the network was set up to the Dish receiver, the hopper, then we started having problems with the message "router not detected"Have you set up the network on your DISH receiver? Which receiver do you have?
Obviously, there's an issue with the Hopper's Network Card.Yes, the network was set up to the Dish receiver, the hopper, then we started having problems with the message "router not detected"
He should call for a tech visit.Obviously, there's an issue with the Hopper's Network Card.
That’s a good point that I forgot about, if the hopper is connected to a Wi-Fi extender, it will cause the kind of issues that the op is seeingI had that problem once. Turned out to be an internet signal booster. The signal from the router and the signal from the booster confused the receiver.
