As promised, my first impressions of Comcast HW, programming and service. I was a Dish sub from 12/98-5/05, with a year as Comcast sub in the middle, from 2/03-1/04. I recently moved, and decided to take advantage of the situation to check out the new Comcast services and HW, while also creating the necessary Dish hiatus, so that I may return to Dish through SBC with their upcoming 2Wire Media Portal. (I am also currently in charge of a 9 receiver Dish commercial account, where I work.)
I've had my Comcast Motorola DCT-6412 since Saturday. It is a pretty nice unit. At the time of Dish disconnect, I was using a 721 and 811. I will try to break down my impressions/comparisons by category.
Physical attributes:
Lower profile than my old 721. Smoother appearance. Flat front panel vs. the curvy front panel of the 721. Nicer looking than the two-tone, weird curvy front of the 811, as well.
Advantage: Comcast 6412. (Subjective opinion, of course.)
Program Guide:
The iGuide interface is clean and quick, lots of grid cells, program info shows in top left corner, video in top right corner, all very similar to the 721, and way superior to the clunky EPG on the 811. I also do not lose EPG info while watching local HD, as happens with the 811.
Advantage: Tie with the 721. Comcast 6412 over the 811.
Menu
The menu system is clear and concise. It also keeps a video window open in the upper right corner, which the 811 does not. It does not have as many options as the Dish receivers, which I miss. Plus, the unit must be powered down to access some HW settings, such as HD and CC settings, which is incredibly stupid.
Advantage: Dish 721, but the Comcast 6412 over the 811.
Add'l Features
The 6412 only has one favorites list. It is only accessible through the menu. (I have created a macro in my universal remote that takes me there, though.) But, Dish receivers have 4 favorites lists which are accessible by simply pushing the guide button multiple times.
Advantage: Dish
The 6412 does not have PIP, even though it is a dual tuner model. The swap function works easier than the 721, though.
Advantage: Tie.
Comcast's channel assignments are goofy. This is due to many basic channels being in the analog band, while higher tier channels on the digital band. It makes for a channel number nightmare. Dish's channel assignments are fairly logical.
Advantage: Dish
(However, Comcast has just begin their digital conversion to QAM256, similar to upgrading to MPEG4, wherein they create add'l bandwidth to simulcast all analog channels in the digital band. This will enable them to group channels together in a more logical fashion. As such, I'd say that Dish's advantage in this area should disappear shortly.)
DVR
I've only recorded a handful of shows so far. They all were successful. Easy to use recording interface. BUT, and it's a big but, the start early option is only in increments of 15 minutes!!! End Late is in normal 1 minute increments, though. OTOH, the 6412 can record HD. The DVR screen on the 6412 has both DVR recordings and scheduled DVR events (Timers in Dishspeak) options. You must then choose one to view. Also, once in the "scheduled DVR" screen, you must scroll day by day, instead of listing them all on one screen. A time-waster.
Also, 721 has double the hdd size.
DVR Interface advantage: Dish 721
DVR hdd size Advantage: Dish 721
HD DVR advantage:Comcast 6412 (No HD in 721. No DVR in 811. From all I've read of the 921, I'd say the 6412 probably has the advantage there too. I cannot compare it to the 942.)
HD
PQ in HD is excellent. Local HD includes all four major LOCAL nets, plus LOCAL PBS, plus one local independent in HD, plus local RSN in HD. National HD includes Discovery, ESPN, InHD, InHD2, and NFL HD. Premium HD includes HBO, MAX, Starz, and SHO in HD. No futzing with OTA which makes things easy. OTOH, I do lose my local WB and UPN HD programming.
Local HD advantage: Comcast
Sports HD advantage: Comcast
Premium HD Advantage: Comcast
National HD Advantage: Dish (Voom Originals and TNT-HD.)
Equipment Advantage: 6412 over 811 (See above regarding the 921 and 942.)
Programming
The Digital Plus package has everything in AT180, plus maybe a dozen or so more channels. Plus, Sundance (one of my favorites) is included, as opposed to Dish making it part of the SHO premium pack. Also, only a couple of shopping channels vs. Dish's 12. Nice touch there.
Advantage: Comcast
Price
Different cable systems, even within the same company, have different pricing. So, I can only compare my Comcast area to Dish.
Comcast
Digital Plus $59
HD & DVR fee $10
Analog channels for 2nd TV $0
Upfront equipment cost: $0
Dish
AT180 w/locals $53
HD Pack $10 ($15 w/Voom)
DVR Fee $5
Upfront equipment cost: $250
While the monthly cost is approx the same. Dish has a huge $250 equipment fee for a receiver that you do not even own! Plus, Comcast offers $25 off for 16 months, for a total of $400 savings. That's a huge $650 price advantage to Comcast. (So much for the cable pig.)
Advantage: Comcast
Service
I've only dealt with Comcast phone CSR's a couple of times, mostly for the order process, once for a problem that was simply user error. (Doh!) Each time, they were courteous and knowledgable, unlike the hit or miss CSR roulette with Dish.
Advantage: Too early to tell.
The Comcast installation tech was fast, polite, and surprisingly knowledgable regarding HD and home theater. OTOH, I asked him to hook up the BR outlet (the F connectors were missing.) He did a nice, neat, quick job up there, but didn't check the line for signal. It turns out the BR feed was not terminated in the utility closet. I had to crimp a couple of connectors, and add a couple of barrels myself.
Advantage: Comcast. (Even with the incomplete Comcast BR install, The Dish installer was so amazingly incompetent, that the Comcast guy would have had to have killed one of my cats to get a lower mark.)
Comcast will replace defective equipment for free. A tech can come to your home, or you can swap it out at a local Comcast office. Dish charges S&H fees and/or monthly $6 DHPP fee.
Advantage: Comcast
Comcast does not charge a fee to downgrade programming. Dish charges $5.
Advantage: Comcast
Summary
Personally, I'd probably be happy to stay with Comcast from this point on. You know, if the 2Wire MediaPortal turns out to be a bust, I will have no problem staying with them. But, I'm looking forward to MP's cool features and functionality. The Voom Originals will be nice too. Although, Comcast might be adding them by then, as well.
Program Guide:
Menu
Add'l Features
Advantage: Dish
Advantage: Tie.
Advantage: Dish
DVR
HD
Programming
Advantage: Comcast
Price
Comcast
Digital Plus $59
HD & DVR fee $10
Dish
AT180 w/locals $53
DVR Fee $5
Advantage: Comcast
Service
Advantage: Comcast
Advantage: Comcast
Summary
