I was told by the dish tech that the dish 500 I currently have pointed at 61.5 can not be re-pointed to 129. He said that 129 requires an oval dish becasue it is lower than 61.5. Is he right?
If the 500 will work for one sat, it will work for another. The tech probably thought your dish was set up with 2 lnb's. I assume that you use the single yoke and not the Y yoke???
Maybe there's more money in it for him if you get a new dish???he told me they were wrong and I needed to buy the 129 dish.
I'm attaching a link to a map supplied by Dish. You can see that you're right on the edge of the exclusion area for the Dish 1000, so 129 reception could be problematic for you.Savannah, GA
I'm just saying that he might truely need the bigger dish for 129, since he's on the fringe.Well if he's outside the reception area the original tech was still an idiot because the dish he wanted to use won't work either.
Yes FOX sports South HD.bigdaddy, is there something on 129 you can't get from 61.5 ?
Where are you located, bigdaddy? There are places in the NE and SE and South Texas that really can't see 129, and there are a lot of fringe locations that require the bigger oval dish, the Dish 1000.2.
Holy sh*t!....Unbelieveable...Was this a tech in the process of trying to get out of doing a job?I was told by the dish tech that the dish 500 I currently have pointed at 61.5 can not be re-pointed to 129. He said that 129 requires an oval dish becasue it is lower than 61.5. Is he right?
