Dish Support - Would You Be Happy?
posdish
14
I would like to relate my bad experience with Dish Network over the past 1-2 months. Some of you may just see this as a long, useless rant, and that is your opinion, but I am posting so that others might realize what they are getting into and be warned about the complete lack of customer service they might receive from Dish and *SOME* of the retailers Dish chooses to use.
I am a technical type person and have always been interested in DBS from either Direct or Dish but cable had always kept me satisfied – until I could not get the Center Ice Package from my provider. So, I decided to finally look into a system and, liking the ‘look and feel’ of Dish, I decided to go with them.
I contacted Dish directly to purchase the system but they ended up sending out a local retailer to do the install. I did not think much of this and thought this was just the way Dish does business. I also did not realize that I would be stuck with the local retailer after the installation – I was mistakenly under the impression that they would just get a commission for the original install.
My original install was little more than a month and a half ago. With me not wanting to use diplexers, brand new quad shield RG-6 coax was already run directly to the “TV 2” rooms from the rooms where the dual input receivers were to be located. On the south side of my house with clear line-of-sight to the 110 and 119 satellites, a hole was already predrilled from my attic – and coming from that hole were two additional new RG-6 cables running back to the receiver rooms, one upstairs and one two stories below the attic. I had also run new phone line to one of the rooms.
So, when the installer arrived, the only thing left for him to do was to put the dish together, mount it, peak it, ground it, and plug the receivers in. What should have taken an hour tops took nearly six hours! Why did it take so long? The installer insisted on mounting the dish elsewhere on the back of my house because he said the skew of the dish would make it hit the house. He drilled another hole from the attic and had to move my two RG-6 cables for the LNB. He later said the skew of the dish would have actually turned the dish away from the house, not toward it, and that he had made a mistake. The mistakes continued.
Even though the installer was told and shown the SEPARATE RG-6 cables intended to back feed the “TV 2” rooms, he insisted on hacking into the RG-6s from the LNB to put in a diplexer. To keep any connection problems to a minimum, I had wanted as few cuts and barrels as possible in the feed line. Before the installer left, I asked him to fill the holes from the attic with caulk and was told, “Oh, we don’t carry that.” I had to go find my own caulk for him to use.
The night after the install was complete, I discovered that apparently no ground had been run from either the dish or the coax. (Yes, I should have checked this better before the installer left). To my shock, though, I found the coax “grounded” about 40 feet from the dish INSIDE my attic to an air conditioning unit / gas furnace. Having great concerns over this, I consulted the forums on satelliteguys.us and the NEC code and decided the ground was not adequate. I contacted Dish support, they agreed the ground was bad, and set up a service call to have it corrected.
The technician arrived with paperwork in hand that clearly said he was to correct the bad ground to my satisfaction. He checked the ground INSIDE the attic, told me there was nothing wrong with it, and told me that “we do that all the time.” I said that it was not acceptable, that it appeared to be against code, that Dish agreed, and that he was here to correct the problem. At this point, he told me that I did not know what I was talking about and that I did not understand anything about satellite installation. I then asked him to explain to me how the grounding was satisfactory. At this point, he called his supervisor on the phone, asked him why it was satisfactory, and halfway tried to relay the answer in terms – as he put it – “that you can understand.” He ended up bumbling about how grounding something does not protect it from lightning but then said it does protect it from lightning by reducing static charge – something I did already understand.
I further expressed my concern with the ground and the fact that a home inspector would nail me for it when I try to resell my home. He relayed this to the supervisor, told his supervisor it was an easy job, and hung up the phone. He then told me that the ground could be corrected but that he would not do it because the original installer would lose some money for the original install (of which I had personally done 90%). I told him that who gets what is between the installers and the employer and that his paperwork said to correct my problem. After this conversation escalated to the point where the installer was yelling at me and berating me in my own home, I escorted him to the door and kicked him out of my house.
I immediately called Dish support on the phone to relay the situation that had occurred. The support representative talked with a supervisor, called the retailer’s dispatcher, and informed me that the retailer would call me back within 30 minutes. After 4 hours of not receiving a call, I called Dish back and was connected to a supervisor. The supervisor assured me the problem would be corrected and arranged to have a Dish Field Service Supervisor call me back.
Since neither the Field Service Supervisor nor the retailer ever called back, I again had to call Dish network and spend 2 hours re-explaining the situation to more support personnel and supervisors. I was eventually connected to Dish’s executive resolution department at the corporate offices.
The executive resolution employee assured me that the problem would be corrected and allowed me to file a complaint about the retailer’s behavior in my home. He also setup a service call with Dish’s Regional Service Provider (RSP) in my area and requested that a Dish Field Service Supervisor join the tech during the service appointment. Because, as he said, this was a direct install (meaning I had originally called Dish), Dish could sidestep the retailer and go through the RSP.
I took vacation on the scheduled service date and waited for the RSP and supervisor who never showed up. I called the executive resolution number back and was told that the retailer was scheduled to come to my house to perform the service two days later. I reiterated the fact that it was the RSP who I was insured would come to my home with a supervisor and not the retailer. My service call with the RSP was then rescheduled, but the retailer STILL SHOWED UP the day before the RSP was rescheduled to be here.
I quickly drove home from work to meet with the retailer’s technician who assured me he would correct the ground to my satisfaction. At this point, I just wanted the problem fixed so I agreed to let him do it instead of the RSP – if he would do it right. Fortunately, he was very friendly, did what appears to be a good job, and did not insult me like the previous technician had. Being mostly satisfied with his work, I called Dish and cancelled the call with the RSP.
I finally thought my ordeal with Dish was over until about two weeks later when I lost all signal to my downstairs receiver. Fearing another debacle with the retailer, I troubleshot the problem myself and eventually found the culprit – at least two bad crimps / connectors on the coax attached to a diplexer in the attic (touch the wires slightly and signal comes back; let go and it goes away). I unplugged my receivers, replaced the connectors with quality compression fittings, and voila – satellite downstairs again. Note that these connectors would not have been there if the original installer had followed my instructions not to use a diplexer.
Life with satellite was good again until last weekend when my receivers started experiencing a strange problem: at times I was getting two completely different signal levels on different inputs on the SAME receiver for the SAME channel, transponder, and satellite. After discussion on satelliteguys.us, I talked with Dish support who diagnosed the problem as a suspect DPP Twin LNB and setup a support call to have it replaced.
The day before the appointment, the dispatcher from the retailer (here we go again) called to verify the problem. I told her what was happening and that Dish had diagnosed the problem as a suspect DPP Twin LNB and that it needed to be replaced. My appointment was scheduled for 8 a.m. – noon the next day. Around 11:45 a.m. on the day of the appointment, the dispatcher called to say that it would be between 3 and 5 p.m. before a tech could come out. Having no choice, I reluctantly agreed.
A tech finally arrived at my home around 6 p.m. and inquired about the problems I was having. He had not been informed about the issues prior to being dispatched and, not surprisingly, HAD NO LNB with him! Without an LNB, the only thing he was left able to do was to discuss the problems, look over my installation, agree that it sounded like a possibly bad LNB, and call the lead tech to see if he wanted the LNB replaced. The lead tech said the LNB should be replaced – but, again, the tech at my house had no LNB. With it being so late in the evening, I was told I would have to call the retailer back to setup an appointment to have the LNB replaced, which was the entire point of the current service call that should have taken place between 8 a.m. and noon.
So, I wasted another entire day waiting on support for my Dish system with no resolution. At the moment, the symptoms my system experienced this weekend are gone – so I am hesitant to even reschedule this – but the tech who was here thinks they will reappear and wants me to get the LNB replaced. I guess I have the pleasure of having to reschedule a service call and spend more time away from work waiting for service that may or may not actually get done.
Finally, I am an avid hockey fan who ordered Dish so I could have Center Ice and access to OLN. Dish’s dropping of OLN from the lineup adds salt to the other wounds. Also, I still can not order pay-per-view from my system remote – even after multiple calls to Dish – because the Center Ice package shows up as $129 (greater than $100) on my purchase history even though it is being paid in $43 installments.
I apologize for this lengthy rant but felt its magnitude justified my relaying it to others. I look forward to constructive discussion from the forum regarding this and other customer service issues.
Your issues are warranted. This is what the industry has become. Since the pay for work has dwindled, I now refuse to do such installs that you mention. The industry has to hire at levels of lower and lower experience.
I would have heartily welcomed all the prep work that you did and wished that every customer was so knowledgeable and so helpful.
I often have been laughed out of the customer's home, because the custom installs for which I quoted bids were $150 over anothers. Mine would have included custom wall fishes, the best cables and weatherproof enclosures, etc. Most customers just don't care. They just want cheap. They had the nerve to accuse me of price gouging. These are the people who deserve installs that go bad in 12 months. Ignorance is bliss!
With that many problems with the installation (and if it did not end up being a bad lnbf) I would say that the installation may have to be done completely over if there are a lot of connections in the line between the dish and receivers. I would call and request credit for time without service. They base the credit upon the first time that you called in. I would wait until the problem was resolved before you do this.
I have some people that accuse me of ripping them off for trying to charge them retail for a system or if I even try to charge as low as $25 for a service call. I decided that I am going to charge what I think I deserve no matter what they think. If it is not my customer originally I charge more. I try to help people out but I cannot do everything for free. I do not see anyone doing service/labor for me for free.
Well Im sorry that you have had such a horrible experience with the dealer and the rsp and with dishnetwork, it is unfortunate but as another has posted this is what the industry has become and really its not only in our industry, take heart though as not all techs are like the first two.
sA :: Shaggy said:
wow this thread might take me a couple of days to read :) . can someone summarize it for me like spark notes
LOL!! I was thinking the same thing, that's a pretty big post, I just scroll right past text that long...
Ah, Shaggy, I thought you might be a brother-in-arms given your used dish installation. The post is a little long because it details MULTIPLE missteps by Dish and one of its retailers. I wasn't happy with the length but also didn't want to just post a one liner complaining about Dish having poor service -- I wanted to show evidence of why.
wow after reading it... I would have been even more pissed. Im surprised you stayed w/ E* but Im glad you did. But i do have to say that they never bring what is needed (no offence installers its the work orders :) ) I have had three installers at my house (one i didnt even know was coming) And NON of them had the Dish1000. POSDISH I hope everything works from now on.
sA :: Shaggy said:
... Im surprised you stayed w/ E* but Im glad you did ...
If I could leave I would - but signed the 18 mo. contract before installation. It's a question of how much do I feel like fighting to get out of it & how much do I feel like fighting possible charges to my CC even if they do let me out.
I have thought about sending the ceo e-mail as recommended above -- but what good will it do? Doesn't it just get answered by the same executive resolution people I have already dealt with?
I can say this -- they have turned someone who really likes Dish's product and could have been a staunch E* supporter into someone who will recommend staying far away from the company.
Sorry for the bad experience Posdish, If I would have been in that situation I would have thrown the guy out once he mentioned having to redo or replace anything. I used to work for an HSP, I had three years into the company but I wasn't a YES MAN to the owner or bosses. A 21 year old that somehow fanagled his way to state supervisor fired me for backcharging him on a bad install? Just wondering if you would post the RSP or retailer/dealer name so the others would know who and what to stay away from. I also promotwe using a local phone number for service.
Would that company happen to be based out of poteau oklahoma?
First of all if you were getting a dual tuner, why didn't he use the separator and than use your prepulled cable for the TV 2? Second of all no installer that is worth a sh!t uses hex fittings ever. Big offense to this installer, i would have had you up and running in 45 minutes for Christs sake. Second of all try to get the phone number for a local DNS office, if there is one. Not to say they are the best, but with your troubles, they would send someone out with at least a few years experience, god only knows what you get with an RSP or apparently the retailer in your area. You want it fixed, ask someone on this forum if they are near you, are reputable and you are willing to pay them for their troubles although you shouldn't have to pay, at least this way you know the stuff would work properly. Simple is as simple does, no you can't ground to a gas furnace, that is ludicrous. Don't worry i will be sure to run a separate ground outside to your gas meter, because I feel they want to blow up your block
Dish Dude said:
... and you are willing to pay them for their troubles although you shouldn't have to pay, at least this way you know the stuff would work properly ...
Point is ... I am capable of doing all of this myself and have other technically inclined friends who are willing to help ... like with the coax run from the attic to two stories below. I could buy a new LNB from Scott here and put it up myself in a few minutes. But I shouldn't have to! I expect Dish and the retailer to do their jobs.
Maybe I should start doing this and charge Dish $29 or $99 each time I have to fix something.
Texanmutt said:
Perhaps that is why dish uses them on the little 6" wires that come with the separator.
it is. They like to piss us off. :mad:
Personally I think the little wires from the seperator should be the kind that don't require screwing on, sure they'd come off easier but they'd go on easier too :)
Forced program guide download
Combine Dish Pro Plus with Directv Antenna?
