dish pointing
avln
7
i hope you will help me.i got a dish 500 from a friend so i don't have any manual.i got 110 fine. but no signal for 119.can you tell me the skew for zip code 11729.thanks
For 11729:
Dish 500
Azimuth* 246
Elevation 27
Skew 127
61.5W
Azimuth* 175
Elevation 41
(no skew)
*Azimuth numbers are already adjusted for magnetic deviation. They should match your local compass reading.
I had fun pointing one of these. What kind of lnb do you have on it.
twin or dual?
Note one of them has an switch build in. That is what I did not know and I wasted time on it. Pointing the dish after that was easy.
Oh ya the receiver should also be able to tell you skew once you input your zip code.
Good luck!
are you trying to install a Dish 500 for Dish Network or for FTA?
There isnt much on FTA that you can get (the audio channels)...if you are trying to do this for illegal use we don';t allow that here :)
The only way to legally get (almost) all the channels on 110 and 119 is to subscribe to Dish Network. A legal FTA system will only get you a stray channel or two, plus some audio channels.
and on that pleasant note.....CLOSED
Obviously someone didnt read the post that says "No Hack Talk".
KU-band LNB question for TELESTAR 11
Need some help..
