Dish Network,
How I DON’T Love thee, Let me count the ways…
Arrived an hour outside of the scheduled time for installation.
Left Dish Network Trash in the street in front of my house
Used my ladder without permission
Did NOT return my ladder to its’ original location when done
Did NOT properly align the Dish Network Dish (Fluctuating around 70% - 75%)
Although this is within guidelines of Dish Network it does NOT represent a PROFESSIONAL installation
(When realigned it was over 100)
Removed Direct TV dish when told specifically to LEAVE it intact
Destroyed Direct TV Dish requiring replacement
(Left it laying on the ground alongside the house even though they walked right past the trash cans)
Installer repeatedly moved the Digital Recorder while turned on…
(Problems caused to the hard drive by this activity are well documented and are not covered by the 90 day warrantee)
Replacement DTV Dish did not have a ground connected
Although 4 leads were tailed down from head of DTV dish only one of 4 leads into the house had been prepared for switching back to DTV (Installer was told of the return to DTV)
Second installer after being shown the mangled DTV dish did not bother throwing it into the adjacent trash can.
(Knowing the previous problems he might have at least asked if he should take it with him or throw it away)
The Original installers did not properly connect the receiver to the existing system
(Second TV was not set to TV2)
(DVR was locked in Dual mode)
NTSC Outputs for TV2 were tied to Video 1 of Primary TV
Remote control was not programmed for use with the TV
No use instruction was provided in the use of or differences between DTV and Dish Network…
Dish Network Support
Let it be known that 3.5 hours of getting bounced around voicemail, being disconnected, refused access to a supervisor pushed me to my limits…
The final straw was that when it FINALLY worked, I did not have all the same local channels that I was told I would have when I signed up for the system. , although Dish Network did substitute the BINGO network…
Buyer Beware...
Dont order until you make sure WHICH locals Dish Includes
Dont sign the release until you check to make sure EVERYTHING works..
Thankfully, I had not disconnected my Direct TV and cancelled Dish within 72 hours...
The phone lines to cancel service on Dish Network are jammed...
Buyer Beware...
