Before I switch from Dish to DTV, I have a question about viewing in multiple rooms.
My house is prewired, one coax cable to each room. I currently have Dish Network, three dual tuner DVR's ability to see programming in six rooms. All cables were pulled to one central location, the exterior wall outside my garage, so I have six coax cables at this point.
Dish uses the diplexers and a DPP44 switch to feed two sat signals from one dish to all three dual tuner dvr's. I use to have Direct TV and I like DTV, but really like being able to access the DVR in more than one room. My delimma is that I do not want to pull more cables on the out side of my house and there is no way to pull new cables along side the ones that were pre-installed when the house was built.
Questions:
1. Can Direct TV use one cable to bring in two Sat signals to the HD DVR Dual Tuner?
2. Can you split the signal from the dish and send it to three seperat Direct TV dual tuner DVR's or do you need multple dishes?
3. Without physically pulling a second coax cable, is there any way to backfeed the output signal through the incoming coax and send it to another TV. I'm ok with only being able to see the same programming in the second room. Will a diplexer work for this?
Questions:
