Dish Network and Camping/Tailgating question
go4it24
16
meridian ms 39305
i have dish network and would like to take it camping.....when using a angle caculator/finder it asks you which satellite to align with. can anybody help? i would like to get my hd channels if at all possible. also when you find your angles what is true Azimuth and mag Azimuth?
PLEASE HELP ? ? ? ? ? ? ?
Your SD stations are on 110 and 119 if you have a dish 500 system and your HD 's are either on 129 or 61.5, depending on your location. The azimuth magnetic is the direction you point your dish using a compass and the azimuth true is without magnetic deviation. (Use magnetic)
Here's some information that might help. Setup and aiming of the protable RV dish
TV Dish Setup shows how we set up our dish. For the Dish 1000 dish, you need to download the Di ah 1000 manual from Dish to get the setup values. You start with the ZIP code and that gives you the azimuth, elevation, and skew.
You can follow links from that page about tripods to use.
ESPN HD Pixelization
channel 103 ppv?
