We signed up for Dish Network in August since big dish is being obsoleted. We are using the 722k duo with TV1 in the basement family room and TV2 two flights up in our bedroom. For the first month, it worked great! Now we have the following issues. We are on our 3rd receiver and still are plagued with these problems.
1) Each morning, you cannot turn on and view TV from TV2 until you go two flights downstairs to turn on TV1. Most mornings it goes through the "Acquiring Signal" process which takes about 5 minutes.
2) If the receiver sits without being viewed (gone to work as an example) it will not record shows in the evening unless we have turned it on (via TV1) prior. It is like it goes into hibernation and cannot wake itself up.
3) If you are watching a recorded show and another show is going to record, or two shows are set to record at the same time, it will freeze. You then need to go down to the physical unit and turn it on. It will have to go through the Acquiring Signal process and you now have missed 5 minutes of your recordings.
Are other users having these same issues? If it is not fixed soon, we're going to have to give up on the Duo DVR route and get DishNetwork to give us two DVRs for the same price.
