I know the 121 and 105 Satellite for Dish Network are FSS KU band Satellite. I have a camp with a slave set up there and my house with 2 Rec. I know I can get 1 super dish for 50.00 But I need 2 super Dishes and Dish want 200. dollars for the 2nd one. I have got a KU LNBF FTA that will go on my 3ft dish. I also got DP 34 switch. I know dish Network says you can't get the 121 or 105 satellite with a 2nd dish. But I don't see way that is. I can get all the other satellites 61.5,110,119 with a single dish. I have tried it and no luck YET. I have been installing c-Band and KU on C-Band and also Dish Network and Direct for 19 years. I know KU is more harder to find but this is not my 1st time doing it. I have a meter and I got a satellite with my KU LNBF and 3 ft dish but I hook it to my DP 34 switch and goto my DP510 Rec. I put my dish 500 on 1 and 2 input and my KU on 3rd input. and then run switch check I know my dish 500 is all set up right. But after running switch check it finds the DP 34 switch but it doesn't find any satellite.. My dish 500 are using non DP LNBF dish says it should work with dp 34 switch. But I need to get a DP LNBF and put it on my 500 dish and try it again. I have DP-LNBF later today. But has ANYONE got the 105 or 121 satellite with a 2nd dish up and running yet? I also need to try a sw 64 switch which I KNOW it will work on NON-DP LNBF and that switch will take 3 satellites. When someone tells me it is not will not work I go out of my way to prove them wrong. I not to bad with me for the price because I can get or have most parts sitting around here.
