Dish is up and running!...now questions!
Got the Coolsat 4000 pro this week
Have the P* Dish and KU LNB
Got it on a fixed mount, ran the coax, and am getting some channels!
I do however, have a few questions that I hope the forum can answer... ...perhaps you can answer one or more? ...here we go!
QUESTIONS
1) Lyngsat shows SBS6 having a bunch of Ku NBC feeds. The OHIO NEWS NETWORK comes in fine. But I'm not getting the feeds...why?
2) I was connecting my H/V coaxes up to the 4:1 switch and forgot to turn the Coolsat off ...now #2 will not get a signal to the receiver. Is it possible to kill one of the ports on the switch? After this happened, I began using port 1 for horizontal and port 3 for vertical (or vice versa), and that seems to work okay...suggestions?
3) Some satellites (like SBS6) are not listed on the Coolsat menu. Why? And does it matter which satellite I use to scan a new satellite (as long as I watch the LNB frequency..10.750)? I've noticed that some of the presets give better signal strengths even if the settings are the same as another named satellite??
4) When I add the D* LNB to port 4 on the switch, will I have to make any special changes to the menu before doing a blind scan?
5) Anyone have plans/pics for a cheap manually operated polar mount?
6) Sometimes a blind scan will list a channel more than once. Why?
Sorry to ask so many, but I've been saving them up for a while!
I thought this would be better than starting 5 or 6 new threads...
Thanks in advance to all...and thanks satelliteguys.us for the forum...it's great!
QUESTIONS
