I have a Dish 500 (mounted on chimney, above second floor in Townhome) with DishPro Quad feeding into DP34 Switch for a (3) room setup. Since I’m looking into getting the new Dish Voom Deal (adding another Dish), I may have to change my wiring/switch arrangements.
Since I have been looking into my wiring I was surprised to find out that it had not been “Grounded” at any point. From what I have read and researched I should route the (4) cables out of the DishPro Quad into “Grounding Blocks/Proper Grounding” before routing cables to the DP34 Switch. Since Dish is located on chimney, the distance to the main “Grounding Source” is quite a long ways and is not the same as point of entry. Does length of Grounding Cable to Grounding Source matter? Is there an ideal point to add Grounding Blocks? Does “Grounding” system weaken signal strength or create performance problems, etc…?
Does it matter if Switches such as DP34 or DP44 should be mounted In-doors (such as In-Door Distribution Panel, etc..) or Out-doors? Should they be mounted close to the Dish or does reasonable distance matter?
Any help would be greatly appreciated.
