dish installation q's
rsx
hi all
got a system set up for directv with a round dish with one LNB. i'm trying to upgrade to a three LNB dish but for some reason i can't get anything on the new dish.
even though i'm installing in the same location, same post, i can't even get the "A" satelitte (101) with the new dish.
where can i verify the tilt/elevation/azimuth settings?
rick
Inside the setup/aiming menu of the receiver itself.
Manually set it to 3 LNB dish or multi-LNB dish. (what make & model receiver?)
Type in your zip code to get the AZ/EL/Skew
yeah, i tried that but i cannot get the three LNB setup to work. its weird that the one with one does but not the three. i thought maybe the receiver was giving me the wrong information so i wanted to cross reference it elsewhere.
Are you pointing the dish at the 110 sat? The single lnb dish points at 101, but the 3 lnb dish points to 110.
The recommended way to align the Phase 3 is to line up with the 101 initially, not the 110.
See: http://www.directv.com/learn/pdf/12429_00_AntennaManual_1D.pdf
It may help the OP if he covers the 110 and 119 LNB with foil, sets the Dish to round dish, get alignment to 101, then set dish to oval, the 110 and 119 should then fall into place if skew is set correctly.
HR10-250 to H20-700
Connecting all my devices together!!??
