Dish Help!
suibuliu
35
Hi, Guys,
I am a FTA newbie, and I bought this dish along with a KW-21 LNBF (a cheaper one?) and a Kusat 2600a receiver, and I had a hard time pointing the dish to the sat (G3C).
I am living in Calgary, Canada, from Sadoun's calculator, the elevation is 28.8, so I set it to 29 (you can only get that accurate?) and set Skew on my LNBF to 15 clockwise (look when facing the dish).
But I have hard time decide the distance between the "flat head" of the LNBF to the center of the dish. The Winegard site says it is 17.56", but I could not get that close, the closest I can get is 19.5", and from a web site, it says there is an error on Winegard's number, the correct distance is 19.5", what is your experience? or this distance is not that important?
Thanks!
Suibu
Also, the same web site says "the elevation gauge on the mount is 1.5 degrees in error...So to tune a satellite quickly using the dish gauge , subtract 1.5 degrees of the satellite elevation that you want."
What is your experience on this?
Just split and moved this from the review area.
The LNBF should be as far from the dish as possible, then moved/skewed to get the best signal quality you can get.
I have had no issues with the elevation being off, again use the signal quality as your guide!
Conduit attached to pole mount
just cant kind G10R
