My system presently has 2 HD receivers. A 722 and a 612. I want to connect 2 more 612 receivers. I want to disconnect the signal presently going to the 612 and add a ???? to connect the 3 in parallel. What device do I need? Thanks Martha
The DPP44 should come with a power supply.What will power the DPP44? Martha
What say you tell us what you want to end up with receiver-wise and let us take a shot at figuring it out as opposed to you holding information in reserve?I have a DP34, so if the additional receivers I want in Parallel are VIP 211, The DP34 should work???
You need 3 cables from your current LNBs into a DP34 to give you the 3 satellites that you are using. The DP34 number means 3 inputs to 4 outputs. The 722 requires 2 outputs from a DP34 the 612 needs 2 additional outputs from the DP34. You have no outputs left for 211s tou could add a second DP34 but you are going to need 6 cables from the switches to the 4 receivers. DPP separators are not designed to work with Dish Pro switches so you can't run 1 cable to the 722 & 612 as you are doing now.I have a DP34, so if the additional receivers I want in Parallel are VIP 211, The DP34 should work??? Martha
We appreciate the update!Dish guys came and installed another dish and all worked well Martha
