Hello -
I have a few questions hopefully some of you can help me with.
I currently have Dish Network using their Standard DVR, I want to upgrade to HD and a HDDVR, but not sure what the requirements are?
1) Currently my home is built with Cat5 Coax cable is that sufficient to run HD through? Will the installers work with that or require a new line?
2) Will only one cable be required to run from the "DISH" to the receiver? I kno with Direct-tv said they had to run two cables and drill through the side of my house or to get a "Single wire Multi-switch". I believe Dish Network receivers use a new technology where only one cable is required? I am using their standard DVR service, so would that work with HD?
I only have only 1 HD TV that this would be installed on. Any suggestions would be great.
Thanks. for your time!
