Okay, I've run several searches and not found the answers to my questions, so here's a new thread.
For Dish Network multi LNB dishes, how does one interpret/predict signal quality?
Since the LNBs are on a horizontal plane I would tend to think the horizontal (width) dimension would be more critical. Is this correct? The trend in the Width column tends to support this. However, the Height column does not seem to correspond (the 500 is bigger on this axis than the 1000 and 1000.2).
Along the same lines, is a Dish 1000+ going to have significantly better signal levels than a Dish 1000.2? Ignoring the obvious difference of the 118.7 LNB, is the 1000+/DPP44 really $250 better than the 1000.2 with DPP Triple and integrated switch?
EDIT: One other question that I forgot. When referring to a non-circular dish, which dimension does one use? In other words, is the 1000.2 a 19" dish or a 24" dish?
Thanks!
Red
Code:
Mast Height Width
Dish 300 1 5/8" 18" 18"
Dish 500 1 5/8" 22.5” 20"
Dish 500+ 1 5/8" 23.8” 30.9"
Dish 1000 1 5/8" 18" 23"
Dish 1000.2 1 5/8" 19" 24"
Dish 1000+ 1 5/8" 23.8” 30.9"
Thanks!
Red
