I have a 76cm, I think wineguard. Got it with dms sg2100 and Invocom quad polar from ebay a few years back. The flange on the dish was bent in one spot and the foam it was packed in was smashed there as if the box was droped on the edge.
I spun the dish on the floor and it seemed to touch all the way around. No sign of warpage, so I put it up. Had a hard time with alignment. The elevation seemed way off from what it should be, so I emailed wineguard and got the triangle diminsions to figure where the lnb should be. It was more then an inch low towards the bottom of the dish and out. I aligned it that way and added 2 support bars because of the heavy lnb. But I still had problems aligning the arch. I could not get it correct on both the ends and middle of travel. Best I got was ~58w-129w. Got tired of messing with it and used it that way.
A few months ago I was on the roof and noticed the lens was nearly gone, but was bussy at the time so let it go.
Last week I took the dish down to work on it and the lnb. Found the lnb was off to the side by about 3/4 of an inch. I was concerned that trying to bend the arm side ways would mess up the dish, so I added a couple of washers to where it mounts to the dish to angle the arm over. The idea was it would also keep the arm aligned with the mount as it has a bolt that goes through the rotor arm and there is no adjustment there.
I got the lnb aligned according to mesurements and then added some squares of foil tape to the dish. Painted a chunk of cardboard black and taped it to the front of the lnb. The foil tape doesn't reflect well enough to see on a light surface.
I angled the dish at the sun for the brightest spot on the card board to find the true focal point. According to that, the lnb still needs to go another inch to the side and another 3 inches up towards the top of the dish. Could the dish be warped that bad? 3" is well above where wineguard said the focal point should be.
