I have an old Star Choice DSR 207 receiver. What would be the right generic dish size and LNB to use with this receiver? It's for a cottage in upstate New York. Where would I beable to purchase this hardware? Thanks
Nice alternative I am going to check it out. If the Direct TV slimline dish is compatible with the Shaw Quad LNB can the LNB be a ku instead of the xku? I would like to go with the larger dish at 75cm because my house is surrounded by tall trees. Does this larger size dish impact my Shaw DSR 207 current receiver and would I need a different ku LNB. The Mad Hatter said; "If you don't know where you are going, any road will get you there." When it come to satellites, I don't know where I'm going but I know not all satellites systems will not get me there with my current receiver.
Thanks for you help
Hi , Can you tell me what model Number of Direct TV Dish will replace the Shaw Direct 75cm dish.You can use a direct tv Slimline dish with either the quad or triple Shawdirect LNB. It is identical to the Shawdirect 75cm dish. All you have to do is take the screw off the bottom of the lnb and it will slide right into the arm of the Slimline. Make sure the LNB is the same as your home system.
You don't want them knowing you have another location.
The 75E is 37 x 27 , so just find a slimline that approximate sizeHi , Can you tell me what model Number of Direct TV Dish will replace the Shaw Direct 75cm dish.
Thanks, Ken
Thanks for the reply, I am looking at a Direct TV model 36EDS it is 36x22 It is used for Direc TV International World Service. Do you think that would work for me?
Thanks, Ken
The dish I am looking at is on e-bay and located in California, I am currently in Florida. The dish is not a Slimline however, it is a Direc TV dish. I have not been able to locate a Direc TV Slimline of similar dimesion to the SD 75e dish. I don't want to buy and ship a dish from CA and not have it work. Is their a Slimline dish that will replace my current 60e dish which is too small for HD reception in SW Florida.The dish you need will have Direct TV Slimline Painted right on the front of it. I'm not familiar with the international dish, it looks similar but the focal point might be different. You could try it and see unless someone else here already had and let us know?
Thanks for the help,
Ken
Do you know if Direc TV has a 75cm (36 inch dish) ? Thats my problem I dont know if they do and if they do have a large dish what is the model number. I appreciate your responses. I am sure I can locate a dish once I know what exactly I am looking for.I would look closer to your area, since I would think Direct TV is in your area you should be able to find a dish relatively easily? I would check any recycle depots 1st then the buy & sell adds, and failing that you must have satellite dealers or even an RV dealer may have them. But I wouldn't suspect you need to ship one across country..
