Hello All,
First let me say that this looks like the correct place for this posting. I hope! If not I'm sorry...
Okay here goes. I have a viewsat VSPRO with an ITB 120M dish. The LNB is a Fortec FSKU-V and a SG2100 motor. There are no switches involved in the setup. The problem comes in that the dish will not mount to the motor assembly (without some modification) unless I flip the turn the bracket on the dish upside down. By doing this everything connects okay except one important factor. There is no quality signal at all no matter what adjustments are made. By mounting the bracket on the dish upside down are the angles on the dish still correct. My dishh elevation should be 27. However if I lower the motor so the dish is plumb. The face of the dish in the center is only at 10 degrees. Does this matter. I'm at a loss with no signal!!
Any and all help would be appreciated. Thanks from the new FTA dummy!
