Hi,
I'm a noob, and I've jumped in with both feet. I am struggling like most noobs here with my dish alignment. Please let me know if I am doing something wrong, or if I just need to be more persistant. I am getting some channels, but I'm not sure I'm on the sat I think I am, and I got lost when adding the motor.
Here is what I have done. I Live in Dayton Ohio, 45459 and have determined that my longitude is 84. With that info, my true south sat should be brasilsat b3. I think I have calculated my az correctly, and allowing for magnetic del., my compass heading for true south should be 184. My elevation should be 44
I attempted to align the dish with the aid of an sf-95 signal finder and ended up on AMC3 which is at 87 instead of my desired 84. Today was real cloudy, so I said close enough and went on to adding my motor.
Although I quickly got a strong sat signal, I did not re-acquire the same satellite and got poor results when scanning for channels. I started getting confused on the elevation settings when attaching the motor. The way I understand it is I set the motor elevation to my latitude of 39, then set the dish at 30deg min 6.1 for my del. angle, which I did After a while I got cold and tired and quit for the day.
I quess I have a few questions. Did I do my math correct for my compass and elevation settings? And after that, is the USUALS settings as easy as it sounds. Basically set my Long & Lat on the receiver for each Sat I care about after I have my True south set? Does it still work that easy if I miss my true south sat by a few deg and program on a sat like amc3?
I know I asked a mouthfull here, but I think this is where I'm goofing up.
Your guys conversations here have got me hooked. I'm ready to be part of the community
Viewsat VS2000 Platinum
Winegard 76cm (31") Dish
SG2100 Rotor
Invacom QPH-031 Quad LNBF
4x1 Diseqc Switch.
SG2100 Rotor
4x1 Diseqc Switch.
