Thank you in advance guys. seems like every spring thaw and a wind storm or 2 during the winter I wind up with picture/reception problems with pixilation issues I have the antenna mounted on a 8X8 post that is stuck into the ground about 3' or more that aside, the channels I seem to have pixilation issues with and sporadic 721 message like when bad weather is about to roll in but the weather is clear at least no rain/storms It's overcast today when I marked down the reading below. The channels that seem to be effected the worst are lifetime network and DIY network not sure what satellite they come in on but her is my run down
satellite transponder signal strength%
101 1 98
110 8 69
119 22 95
99ca 9 95
99cb 1 95
99s - not acquired
103s - not acquired
103CS 9 95
103cb 1 95
I have I think the antenna is a swm slimline that runs 4 receivers and a slave 1 genie 3 HR 24/ X different models and one mini slave the Genie seems to have the best reception of all of them I do not have issues with my Local channels that is what the S satellites are for correct? looking for some insight. Seems like I have the dish locked in pretty rock solid but still get the pixilation issues I also get a sporadic 775 error message when I change channels. usually when the channel is switch to one of the ones that like to pixilate possibly a LNB issue . it pops up for about 5 seconds and goes away, my LNB has has 4 cables that come out of it anyone know the correct part for it? it has 3 heads on the lnb.
101 1 98
110 8 69
119 22 95
99ca 9 95
99cb 1 95
99s - not acquired
103s - not acquired
103CS 9 95
103cb 1 95
