Dish 625 doesnt work right
Dishusercan
154
22
US
I just got a 625 dual receiver and on 119 I get transponder 11 to 21 and on 110
11 to 31 and I did the check switch and it says ok , I have a sw44 and port 1 is 110 and port 2 is 119 and when I try to exit of the point dish it says the signal you are receiving is not from the satellite you have selected. I already have a 222k and it is working fine but I can't figure our how to make the 625 to work
From the point dish screen go to the check switch test and test it. Both inputs should come back with both sats in green, if not you have a problem. If they come back fine, choose done. Set the point dish screen to sat 119 trans 19 and wait until under the signal bar it says Locked - Satellite 119 then choose done. Is the receiver new? If so it will ask if your signal is locked, choose yes and it will start a software download.
Eugene abc local back on air?
