I have just acquired a 622. Previously, I had a 921, and I ran component out to a plasma for HD that way.
I also have a CRT projector in my home theater, and I want to run a feed to that projector. With the 921, I used a DVI-to-RGB adapter from my computer monitor, and it worked fine out of the DVI port from the 921. This was DVI-I.
Now, there is no DVI port on the 622. I purchased a HDMI to DVI adapter, but this is DVI-D, so it doesn't fit (there are four pins surrounding the horizontal bar on the DVI-to-RGB adapter, and no holes for them on the HDMI-DVI adapter).
So, does anyone know: 1) Where can I get an HDMI-to-DVI-I adapter, which I can then run to RGB through my DVI-to-RGB adapter, and 2) Will this work? (an alternative would be a DVI-D to RGB adapter, but I suspect that this would either not work or is not available).
The bottom line is I want a feed to the CRT projector so I can still watch HD, and the component output is spoken for.
Thanks.
Thanks.
