Dish 500 Troubles
chronlc
4
Hello,
Im running a dish 500 with 2 single lnb's, these lnbs on the side say dish pro. I have a sw21 switch feeding both signals to my reciever. For some reason I can nail the 119 bird without a prob getting a 109 signal, but i cannt get a signal for 110 bird at all. I have my skew set correctly for my zip code according to the Peak Angles menu in the dish point screen. I am utterly stumped on this as I thought if u could get signal from 119 you would have signal for 110. Also when I go to the check switch menu and do a switch check all i get is:
LNBs: DP-Single
Input: 1
Satellite: 119
Polarity: ALL
Device Sgl
Status: WARNING - Only one satellite connected
Im totally stumped any suggestions or comments would be greatly appreciated.
Thanks in advance,
Chronlc
Thanks bro, I figured it was the switch, I had a sat fidner meter that I just used and i connected each LNB to it and had signal just the reciever was only showing 119. Thanks for the info really appreciated it. :) :)
Thanks again,
Chronlc
J
sparkles on cband
S
Hot drama developing at home
