Dish 500 Legacy Twin
Davevh@comcast.net
18
Las Cruces NM
Gentlemen
The wind blew my tripod over and I think my LNB is toast.
I have a 3900 recvr and a Dish 500 Legacy Twin. I can ordinarily setup my 3900 and dish practically blindfolded. Not so after the wind blew my tripod over.
I cant seem to get it to SEE a bird. When I set it up using my home dish the 3900 works fine. I am running less than 100ft of RG6. It doesnt recognize the switch and it says no device installed.If it is a bad LNB will a DISH NETWORK DUAL LNBF LEGACY (single LNB) work with my 3900?
is it a dual or a twin? they are different
a dual can see one satellite and allow up to 2 recievers to see off it
a twin allows you to see both 110 & 119 and run 2 recievers off of it
a Twin would fit in the "Y" adapter whereas a dual will only fill 1/2 of it
Sir
You answered my question about the dual. I would need two duals to fill my Y adapter so duals are out.
What amount of current should be ging to the LNB from reciever?
Does anybody have any CHEAP used twins lying around not doing anything?
Gentlemen
I think I have my problem solved. I can now SEE 110 but I think the LNB may be SEEING 110 with the 119 side which is probably an elevation prblem. I have more trouble shooting to do thanks to " The Mad Chick In The RV" post.
Did your dish get warped when it fell over? Set your dish face down on a flat surface like a table. If it rocks or you can see light under part of the dish face you need a new dish.
I'm a dish network installer,
Are you still having issues with your currenty sys? If you are drop me a message and I'll help you resolve it!
.. also how did your tripod blow over? ..lol
-tom
Thanks a lot but dont need the help on line current anymore. Dish got warped when the wind blew it over.
I'm an old metals fabricator. Reshaping was a piece of cake. It works just fine even with a couple of dents on the edge. The parabolics are good to go. I was 'seeing' 110 with 119 side fooled with the azimuth and elevation and it works fine now. I can almost set it up blindfolded.
superdish 110 problem
HD to SD Screen Sizes
