Dish 500 Help Needed
rdoody
Hi Folks,
This is my first post here, so hello to everyone.
I'm hoping someone can help answer a question for me.
I have a Dish 500 system with the integrated switches.
The 2 coax lines go directly to my 2 recievers.
What I wish to do is to merge my Antenna signal onto both
satelitte feeds and use a diplexor at the reciever to connect.
What HW do I need to combine the one antenna feed with the 2 sattelite feeds?
Any help wiuld be appreciated?
Rob
A two way splitter on the TV antenna line fed to 2 diplexers, the lines from the dish fed to each diplexer. At the TV set you will need 2 diplexers to split the combined signals out.
Thanks Boba,
Can you recommend a decent UHF/VHF amplifier for the antenna and the
satellite feeds? I'm assuming my signal will degrade some when I split it and
the coax runs are long.
Thanks,
Rob
P284 and Guide Problem
dish ghosting
