If I acquired a Dish Network 322 dual tuner receiver could my Dish Network 3900 be activated on the same account and used along with the 322? I have a Dish 500 Legacy Twin LNBF.
It sure can. But, the problem is your current switch and LNB configuration. Your best bet would be to swap out your Legacy Twin for a DPP Twin.
I'm not sure how/where you're buying your 322, but one thing to keep in mind is to make sure you have a separator, otherwise the previously mentioned LNB will not work.
The 322 needs 2 inputs from the dish with a Legacy system so a Twin will be maxed out. A Legacy Quad could be used but if you are going to upgrade your electronics so you can use 3 tuners a DPP Twin with a separator for the 322 would be the best way to go.If I acquired a Dish Network 322 dual tuner receiver could my Dish Network 3900 be activated on the same account and used along with the 322? I have a Dish 500 Legacy Twin LNBF.
Webbydude,
NO NO NO, the 322 will work just fine with both legacy LNBF's and switches as well as Dish Pro (and Dish Pro Plus) LNBF's and switches. The 3900 will work with Legacy LNBF's and switches and DISH PRO PLUS but NOT Dish PRO (NON PLUS) LNBF's and switches (without a Dish Pro adaptor).
If the OP has a Legacy Switch either (SW44 or SW64) then he doesn't need to change anything although it will require two Cable feeds from the switch to connect the 322. If the OP has a Legacy TWIN then he will need to either replace the Legacy TWIN with Two Dual Legacy LNBF's with a four output legacy switch (SW44 or SW64) or get a Dish Pro PLUS TWIN (although if you have poor or low grade cable it will likely NOT work).
If the OP doesn't want to run extra cable runs or doesn't have a SW44 or SW64 then the Dish Pro PLUS TWIN would be a nice option as it would only require a Single cable to each receiver (Although the 322 would require a Dish Pro PLUS Separator). Another thing to consider is the quality of the existing cable. NON RG6 or poor quality RG6 may NOT work with a Dish PRO PLUS LNBF.
John
Webbydude,
John
