I'm reconfiguring our entire setup at home and I'm running into a problem. I'm using a DISH 222 receiver and in the second room, I have a coaxial connection for the aerial and the coaxial for the second line coming from DISH. I've put a splitter for two inputs and one output to the television and when it attempts to scan for the channels it misses channel 72 to pick up the DISH programming. When I put the DISH coaxial in by itself, it picks up channel 72 and I can then view all the channels through DISH on that set. I also see that it's picking up an additional analog signal with the splitter, so it seems obvious that it is seeing the DISH coaxial.
I know this might seem all a bit odd, but what I'm trying to accomplish here is that since I'm only getting SD from the DISH mirror, I'm able to pull in 50 stations locally in HD at least for that set with the aerial connection.
Is it a set issue with it just not reading things right with the coaxial splitter? I can't get the TV to manually override and enter channel 72 to force it to view the DISH channels.
