Hi,
I'm a novice when it comes to dish installs and I've run into a signal problem.
I have a 1000.4 WA DISH and am trying to pick up sat 119, 110, 129. I have a VIP211K receiver and a DP44 switch installed. Not sure i absolutely needed the switch but as long as it isn't causing my signal issues i'm not to worried about it. I have the mounting post installed on my roof and it checks out with the level in both directions. I am pointing the dish using the values from the installation guide for my zip code 54952. it says it should be Skew 117, Elevation 30, Az 221. At these locations I can't get any reception on the receiver. When i was trying different settings i put the dish at a Skew 54, EL 31, Az 215-225 i was able to get sat 110 at a signal strength of about 50-58. The receiver says that all 3 lnb's are picking up sat 110. This is the only setting I've been able to get a signal. As soon as i start moving the skew closer to the target setting i lose all of the 110 signal.
I feel like I'm really close to getting it to work. Does anyone have any tips for trouble shooting this problem?
Any help would be very appreciated!
