C/P from the spec:
"The DiSEqC™ concept is based on extending the present 22 kHz tonesignalling
method, thus minimising the changes required in Tuner-receiver or
Integrated Receiver Decoder (IRD) units, and simplifying backwards
compatibility. However, since the full DiSEqC™ protocol supports a returnsignalling
path and multiple peripheral devices, it is necessary to more closely
define the impedances (at 22 kHz) on the bus, than the simple low impedance
drive (supply voltage modulation) commonly employed with the present tone
method."
Full details/specs can be found here:
http://www.eutelsat.com/satellites/4_5_5.html
Thanks all for bringing up the discussion!
Update: I thought that this point was interesting. Again C/P from the spec page at the bottom:
"Important Notice
Level "2.3" is NOT a DiSEqC™ level that has been standardised by Eutelsat. Other DiSEqC™ products may not work correctly with products using this protocol. Please contact the manufacturer of any equipment carrying the non-standard and unapproved DiSEqC 2.3 logo for clarification.
Eutelsat is now considering the best way to incorporate this new protocol (if possible) in to the DiSEqC™ standard to ensure compatibility with all other DiSEqC™ products on the markets."
