@ johnnynobody. Do it the way KE4EST says. The reason is both of your diagrams have the cable going outside to the SG2100 then back inside the house to the GBOX then back outside to the dishes. (you can't have a GBOX outside for obvious reasons) That is 2 extra runs of cable you don't want to have. Longer cable runs mean more loss of signal & less power for motors & often cause switching & lnbf problems.
This is the way i been running mine for years with no problems.
My Diseqc is inside the house.
Ku needs to be Diseqc and c-band 1.2
i ment Ku needs to be USALS and c-band Diseqc 1.2
I have observed some brands of switches run for years without problems passing the higher motor current draws. Not all switches are capable of the repeated current surges.
Depends on the switch that you get. Some can handle current, some can't.
I know the EMP-centauri can, also the ones I have from DMSI can also pass current without issue.
Always!! Unplug the receiver if it does not have a physical switch on the back, when messing with switches.
As pointed out, they may handle the current, But that spark, although minute, may be many thousand volts. Can it also handle that voltage?
