Direcway dish
stoner2399
14
Hi all I have a direcway dish will this dish and lnb work for Ku band FTA or do I need to get a new lnb also I would like to know what my true south sat is my zip code is 83501 if that helps
thanks
yes it will work just fine. If there is a transmitter on the arm of the dish, you need to bypass it.
True south for 83501 is Satmex5 (you are at 116.9 longitude and its at 116.8)
Well Hello Fellow Idaho FTA'er LOL
Hello, I see by the zip you are in lewiston. I'm clear down by pocatello.
Later,
Josh
Yes direcway dish /lnbf will work for fta ku. A little undersized, but it will work
pretty well. I have one, and it is a pain to aim but once aimed it stays there.
I put mine on a pole for awhile just to try it out on G10 but found an old primestar works much better. For your true south and setup>
Satellite Look Angles Satellite Heading Calculator Azimuth Elevation Skew Tilt LNBF Latitude and Longitude values
Try above link for the sat calculator, pick a sat, and a city near you, it will give you the angles for a fixed dish install.
Hey thanks for all the great info I kind new to all this going to try to hook up by pansat 2700 to the G10r I hear there is alot of older tv shows on that one
BTW how do I bypass the transmitter?
Convert CM120 KU LNB Mount to BSC421
what satellite to scan ?????
