DirectX Video
[ Primary Display Driver ]
[B]DirectDraw Device Properties:[/B]
DirectDraw Driver Name display
DirectDraw Driver Description Primary Display Driver
Hardware Driver atiumdag.dll (8.14.10.0678 - ATI Catalyst 9.7)
Hardware Description ATI Radeon 3100 Graphics
[B]Direct3D Device Properties:[/B]
Rendering Bit Depths 16, 32
Z-Buffer Bit Depths 16, 24, 32
Multisample Anti-Aliasing Modes MSAA 2x, MSAA 4x
Min Texture Size 1 x 1
Max Texture Size 4096 x 4096
Unified Shader Version 4.0
DirectX Hardware Support DirectX v10.0
[B]Direct3D Device Features:[/B]
Additive Texture Blending Supported
AGP Texturing Supported
Anisotropic Filtering Supported
Automatic Mipmap Generation Supported
Bilinear Filtering Supported
Compute Shader Not Supported
Cubic Environment Mapping Supported
Cubic Filtering Not Supported
Decal-Alpha Texture Blending Supported
Decal Texture Blending Supported
Directional Lights Supported
DirectX Texture Compression Supported
DirectX Volumetric Texture Compression Not Supported
Dithering Supported
Dot3 Texture Blending Supported
Double-Precision Floating-Point Not Supported
Driver Concurrent Creates Not Supported
Driver Command Lists Not Supported
Dynamic Textures Supported
Edge Anti-Aliasing Supported
Environmental Bump Mapping Supported
Environmental Bump Mapping + Luminance Supported
Factor Alpha Blending Supported
Geometric Hidden-Surface Removal Not Supported
Geometry Shader Supported
Guard Band Supported
Hardware Scene Rasterization Supported
Hardware Transform & Lighting Supported
Legacy Depth Bias Supported
Mipmap LOD Bias Adjustments Supported
Mipmapped Cube Textures Supported
Mipmapped Volume Textures Supported
Modulate-Alpha Texture Blending Supported
Modulate Texture Blending Supported
Non-Square Textures Supported
N-Patches Not Supported
Perspective Texture Correction Supported
Point Lights Supported
Point Sampling Supported
Projective Textures Supported
Quintic Bezier Curves & B-Splines Not Supported
Range-Based Fog Supported
Rectangular & Triangular Patches Not Supported
Rendering In Windowed Mode Supported
Scissor Test Supported
Slope-Scale Based Depth Bias Supported
Specular Flat Shading Supported
Specular Gouraud Shading Supported
Specular Phong Shading Not Supported
Spherical Mapping Supported
Spot Lights Supported
Stencil Buffers Supported
Sub-Pixel Accuracy Supported
Subtractive Texture Blending Supported
Table Fog Supported
Texture Alpha Blending Supported
Texture Clamping Supported
Texture Mirroring Supported
Texture Transparency Supported
Texture Wrapping Supported
Triangle Culling Not Supported
Trilinear Filtering Supported
Two-Sided Stencil Test Supported
Vertex Alpha Blending Supported
Vertex Fog Supported
Vertex Tweening Supported
W-Based Fog Supported
W-Buffering Not Supported
Z-Based Fog Supported
Z-Bias Supported
Z-Test Supported
[B]Supported FourCC Codes:[/B]
AYUV Supported
DXT1 Supported
DXT2 Supported
DXT3 Supported
DXT4 Supported
DXT5 Supported
EAPI Supported
GET4 Supported
INST Supported
M2IA Supported
NV12 Supported
NV21 Supported
R2VB Supported
RESZ Supported
SORT Supported
SYV2 Supported
TES1 Supported
TESS Supported
UYVY Supported
YUY2 Supported
YV12 Supported
