Signal Connect’s DIRECTV technical supports comes in many forms. Sometimes, we share tips to remedy DIRECTV connection issues. Other times, we educate you about satellite TV equipment. This time, we take a closer look at DIRECTV power adapters. There are a few of them out there, and we identify each and tell you which DIRECTV equipment it matches. This is important information because you never know when you might need to replace your power supply. Let’s take a closer look at the power adapters DIRECTV has to offer.
Do all DIRECTV boxes use the same power supply? Close, but it’s not quite to that point… yet. Right now, most DIRECTV boxes use the same power adapter. It’s the DIRECTV EPS10, which is the most common DIRECTV power adapter. It’s used to deliver power to a wide variety of DIRECTV equipment, which includes:
Note: It can’t power all of these devices at the same time. You’d need a separate power supply for each.
While the EPS 10 seems to be the most common DIRECTV power supply, it’s not the only one. The DIRECTV EPS44 is the power supply for most DIRECTV DVRs these days. For example, this device is used to power the H44 Genie, HR44 Genie, and HR54 Genie. It actually carries a bit more power than the popular EPS10 power adapter.
The EPS17 power adapter has a very specific use. It’s delivers power to the HS17 Genie 2. If you don’t have this receiver, you don’t need the EPS17.
The PI29Z power inserter is not a power supply. It’s a power inserter, as its name implies. This means it puts power over a coax cable so it can be used by outdoor equipment or consumer premises equipment. A power supply, on the other hand, is used to power a receiver. As far as the PI29Z is concerned, it’s something you use to power your dish if you don’t want to power it using your DVR, or if you have an external multiswitch. This device is fairly common in homes that have a DIRECTV satellite installation. Today’s PI29Z replaces an older version with a black out shell.
If so, we have you covered. Solid Signal, an online electronics retailer, is a division of our company. Solid Signal carries all of the DIRECTV power adapters and power inserters mentioned in this post. You might not think you need one of these devices now. You never know when you might need to replace your power supply. If you order one now, you’ll have it before you need it. It sure beats sitting around without DIRECTV while you’re waiting for your new power adapter to be shipping to your home! If you need help, just call our product experts at 888-233-7563.
As an AT&T Preferred Dealer, Signal Connect is able to offer DIRECTV technical support to you and anyone else who enjoys this satellite TV service. Whether you have a question or a connection issue, all you have to do is pick up the phone and dial 888-233-7563. Our DIRECTV experts are happy to help you with whatever you need. Here’s the best part – the DIRECTV customer service we offer is absolutely free! There’s no catch. If you have DIRECTV and need some assistance with a technical issue, Signal Connect is happy to help!
The post DIRECTV Technical Support: Power Supplies appeared first on The Solid Signal Blog.
Continue reading...
The DIRECTV EPS 10 Power Supply
- Broadband DECA
- C31 Genie Mini Client
- C41 Genie Mini Client
- C41W Wireless Genie Mini Client
- C51 Genie Mini Client
- C61 Genie Mini Client
- C61K 4K Genie Client
- C61W Wireless Genie Mini Client
- H25 Receiver
- Wireless Video Bridge
- Gemini for Satellite
DIRECTV EPS44 Power Adapter
DIRECTV EPS17 Power Supply
DIRECTV PI29Z Power Inserter
Need a Replacement DIRECTV Power Supply?
Signal Connect’s DIRECTV Technical Support
Continue reading...
