Can I "move" to Miami from the Tampa metro, considering satellites my dish points at and the spotbeams?
If you are inside the spotbeams, sure. I assume you are wanting the locals and RSNs from that area?
Do I need to use an actual relatives address or just switch to non-paper billing and give any address in that market plus an apartment number?
A five year old map may not be accurate and it certainly doesn't represent any of the HD spotbeams that have been deployed in the last three plus years.I found a spot beam map that shows I am, but it was a few years old. I guess they don't change at all or often?
There is no "old map" of HD spotbeams. Chances are that since you're around 250ALM away, you're going to get spotty reception at best. HD spotbeams are a fraction of the size of the Ku spotbeams and they fall off very quickly at the fringes.
DIRECTV said:Multi-satellite systems are tailored based on your Designated Market Area (DMA) and specific programming needs.
As best I can tell (the info is not 100% accurate) the miami locals are on sat 99 transponder 15.
It includes all the major nets, plus PBS & CW.
See what kind of signal you get on 99/15 before you do anything.
According to gct's transponder map, found elsewhere here on a sticky, FSFLHD is on D10 located at 103W, just like all the other FSN HD channels. So assuming that it gets sent on all spotbeams (as the other RSNs do) changing your service zip code to a Panthers-enabled zip should get you out under from the blackout.
The Ft. Myers market also uses D10 @ 103, TP 15. Even in the northern suburbs of Tampa you should be able to pull in the Ft. Myers spot beam. Looks like 33948 might be a good "move" for you. Not that I'm advocating such behavior.
Move complete.... one box is getting the new channels, the other is not. Can I remotely reset the box or do I need to call in and have them send a signal?
