greetings! New poster to the forum. Hoping for some help. Just back from a camping trip over the weekend where I spent 3 hours trying to locate directv satellite signal with no luck. I am hoping to get a couple questions answered to help me with this as I’d like to learn to do it myself. I have successfully found satelite 101 in the past but had low signal on 103 and was unable to watch HD sports.
Here is my setup:
Directv genie 2 (HS17) brought from home with brand new rg6 ran directly to receiver to avoid splitters etc
Directv dish (not sure what size but it’s big, fairly certain it’s the correct dish as it’s the same as I have at home) on tripod with reverse band LNB
Plumb and level mast
Clear line of site to southern sky
I use a cheap analog squelcher meter to help dial in the signal but I’m not sure it works right. All I get is a constant reading of 10 no matter if I adjust the knob all the way down or up. Is that normal? I’m aware these meters don’t specify which satelite.
Is it possible to calibrate the elevation reading on the adjustment screw? This dish was a freebie and the fine adjustment knobs broke off. Perhaps the elevation angle I had set was inaccurate?? Just guessing.
I’m thinking of replacing the back adjustment unit and also purchasing a used bird dog meter.
Any tips are greatly needed! Hoping to be able to watch HD while camping.
Here is my setup:
